Activity Forums Apple Final Cut Pro Legacy Need help quick, graphic dissolve JUMPS!
  • Need help quick, graphic dissolve JUMPS!
    Posted by Matt Gottshalk on December 6, 2005 at 7:17 pm
    At a client location, almost done editing with a powerbook, FCPro 5.0 and Aja Io LA.
    The problem: whenever I try at the beginning and end of the show to dissolve to a full screen non-keyed graphic, it “jumps” after the dissolve is complete.
    I’ve rendered everything.
    Any ideas?
    Matt G
    Tim Vaughan replied 20 years, 9 months ago 2 Members · 1 Reply
  • Tim Vaughan
    December 6, 2005 at 7:24 pm
    Chances are you rendered out the project, then made a change or two, then rendered again. However, the existing render files are still lodged somewhere in memory. Best thing to do is open render manager and delete all the existing render files. Then re-render everything from scratch. This should take care of your issue.
    Hope this helps. We’ve had success with this approach, and I heavily recommend it, especially when working with stills.
    Tim
