Activity Forums Panasonic Cameras need help now!!!
  • Graham Tees
    November 21, 2008 at 8:53 am
    With P2 cards you have to import the files from the card into whatever edit suite you are using. The info can’t be transferred via firewire, as it’s recorded on the cards as a file.
  • Jan Crittenden livingston
    November 21, 2008 at 11:13 am
    You should go to wwww.panasonic.com/p2hd look under the resources link and download the workflow paper that is relative to the NLE you are working with. When you offload the cards, make sure that you keep the folder structure just as it is and the lastclip.txt file should stay with the folder as well.
    And next time you post your should post in the HVX-HPX forum as those are P2 cameras and you will get more replies, faster.
    Good luck,
    Jan
    Jan Crittenden Livingston
    Product Manager, HPX500, HVX200, DVX100
    Panasonic Broadcast & TV Systems
