Activity Forums Adobe After Effects Expressions Need help modifying this expression
  • Need help modifying this expression
    Posted by Gene Michael patrick on March 27, 2007 at 12:47 am
    Hi all,
    I need to modify the following expression to create a 180 degree rotation on the Y axis. Hopefully it’s not too difficult.
    The expression is: this_comp. layer(this_layer, -1) . opacity. value_at_time ( time – .1)
    Thanks in advance for you help.
    Gene M. Patrick
    DIRECTV
    Filip Vandueren replied 19 years, 5 months ago 2 Members · 1 Reply
  • Filip Vandueren
    March 27, 2007 at 1:03 am
    opacity ranges from 0 to 100
    you need rotation, from 0-180
    this would be the easiest way:
    (this_comp. layer(this_layer, -1) . opacity. value_at_time ( time - .1))*1.8
    you could add value, so the current value of the Y-rotation get’s factored in:
    value+(this_comp. layer(this_layer, -1) . opacity. value_at_time ( time - .1))*1.8
    or perhaps *-1.8 for 0 to -180, but what if you actually need -90 to +90 etc…
    Anyway if the values start getting a bit more complex it ios better to use an interpolation method like ‘linear’:
    linear(this_comp.layer(this_layer, -1).opacity.value_at_time( time - .1), 0,100, -90,90)
    this means: look at where a certain number (the result of your expression) is situated between 0 and 100,
    and return the corresponding interpolated number between -90 and 90.
    Oh and avoid using spaces inbetween your .dot notation.
