Activity Forums Apple Final Cut Pro Legacy Need help in live editing???
  • Need help in live editing???
    Posted by Alimacia on November 16, 2007 at 12:04 pm
    Hello People
    I have this situation I hope you help me & guide me:
    I have
    2 Sony Cameras
    2 projectors
    Video Mixer
    Sound Mixer
    Final Cut Pro 6
    2 Lab tops
    MyBook 500GB
    I want to to get both video and audio from the 2 cam and view the video in the 2 projector at the same time. Also add effects or some labels from the 2 video editing software and display it with video and audio in the 2 projectors. All of that live that mean what I ever I do it should be displayed to audience.
    The questions are:
    – What kind of hardware I need to do this and which website I can get it from?
    – What kind of software I need to do this and which website I can get it from?
    – What the best and correct methodology to do it?
    – What anything else that I need and could help me?
    Please I need your help & guide. Please guide me!
    Thanks in advance.
    Alimacia replied 18 years, 10 months ago 4 Members · 6 Replies
  • Jerry Hofmann
    November 16, 2007 at 1:54 pm
    You’ll need a character generator and more… I’d suggest that you contact a VAR and have them design and setup a system for you. FCP will have nothing to do with it either… you can’t use it for anything except to show pre-edited material… can’t go in and out of FCP live at all.
    Jerry
  • Rennie Klymyk
    November 16, 2007 at 8:02 pm
    [alimacia] ” want to to get both video and audio from the 2 cam and view the video in the 2 projector at the same time. Also add effects or some labels from the 2 video editing software and display it with video and audio in the 2 projectors. All of that live that mean what I ever I do it should be displayed to audience. “
    I’m not clear on this.
    Do you want the pictures from both cams live mixed on each screen at the same time or will it be 2 separate setups in different areas? (one cam+one laptop displayed on one projector).
    Most important – Are you working with DV, HDV or HD?
    and what signal are you feeding the projectors (composite, s-video, component, dvi) ?
  • Alimacia
    November 18, 2007 at 10:43 am
    Thanks for your reply.
    I’m sorry fot this convustion
    the stup that I have
    2 cams connect to one labtop
    2 projectors connect to same labtop mostly through composite cable.
    I want to mix between videos and add some effects to videos such as news bar or anyother effects. Mostly I will work with DV.
    Thanks in advance
  • Jerry Hofmann
    November 19, 2007 at 12:54 pm
    You cannot send more than one signal to FCP, and send out a graphic over this signal at the same time. It’s not a production application… it’s a post production app.
    You need a switcher and hardware that do this for you. FCP really doesn’t come into play at all unless you want to record the signals you’re sending to the projectors.
    Jerry
  • Chris Paul
    November 19, 2007 at 10:03 pm
    Wirecast will do what you want. It will switch & mix between firewire sources, do still & motion graphics, even real-time chroma keys. About $500. Only caveats are that you need a second firewire bus (there are several available for the ExpressCard slot) and lots of VRAM (macbooks will not work, only macbook pro’s)
    Chris Paul
    POV
  • Alimacia
    November 20, 2007 at 6:14 am
    Thanks for all the replys, it was a big help for me.
    I think I will use Wirecast as Mr.Paul suggest.
    Another thing is In FCP I know how to capture from one cam and store it. I have try many times to capture from 2 cam it doesn’t work with me. Is there any solution for this or I should us the video mixer/Wirecast to change the source?
    Thanks in advance
    Ali Al-Qawaeen
