Activity Forums Zaxwerks need help, i need more than just 8 sets for 3d tracking
  • need help, i need more than just 8 sets for 3d tracking
    Posted by Brandon on October 22, 2005 at 7:31 pm
    I am using 8 3d tracking layers for 8 different letters in my project. I have these layers animated to animated the letters in the invigorator. But, I have another object i need to track with a layer. When I change set 1 to use for my 9th object, it takes out my motion for set 1. Is there a work around? Thanks
    Serge Hamad replied 20 years, 10 months ago 3 Members · 3 Replies
  • John Dickinson
    October 22, 2005 at 9:14 pm
    Duplicate the effect and that gives you another 8 sets then just delete the objects you don’t need.
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Brandon
    October 23, 2005 at 12:24 am
    Just duplicate the invigorator? Will the objects still be able to interact? Thanks
  • Serge Hamad
    October 23, 2005 at 7:02 pm
    No. The objects won’t interact. The method is helpful if you are animating a set that always is in the BG or FG.
    You could either duplicate the Invigorator effect, check “Composit on original” or duplicate the entire solid.
    Salut.
    Serge
