Activity Forums Adobe After Effects need help flash to after effects please!
  • need help flash to after effects please!
    Posted by Patrick Vale on June 10, 2005 at 3:53 pm
    im rotascoping a quicktime animation in flash, and then have been exporting the animation as pngs into after effects to composit over the top of the same quicktime. it all matches up perfect apart from about six frames, ive checked the animation in flash and it all matches up so there seems to be a problem when its exported. its wierd cos most of it is so perfect. any ideas? ta
    Josh Michnik replied 21 years, 3 months ago 2 Members · 1 Reply
  • Josh Michnik
    June 12, 2005 at 12:11 pm
    Do you have the footage all interpreted the same? ex. squarepixels? or what about frame rate. or resolution.. Probly something simple like that
