Activity Forums Apple Final Cut Pro Legacy Need help fixing HDV1080i and DVCPROHD 720p60 source footage
  • Need help fixing HDV1080i and DVCPROHD 720p60 source footage
    Posted by Earthworm on August 2, 2006 at 9:59 pm
    What’s the best (highest quality) FCP workflow (catpure and sequence settings etc.) for mixing DVCPRO-HD 720p60 and Sony HVR-Z1U at 1080i 60i in the same sequence?
    The footage was shot with a VeriCam at DVCPRO-HD 720p60 and a Sony HVR-Z1U at HDV 1080i 60i.
    The DVCPRO-HD is digitized at it’s native resolution and I do not have access to a deck to redigitize (unless I rent one).
    I have a Sony HVR-M25U HDV deck but as far as I understand I am limited to digitizing at HDV.
    I did some tests rendering the HDV footage to DVCPRO-HD and vice versa at both 720 and 1080. The HDV footage when rendered at DVCPRO-HD (either 1080 or 720, same result) is jittery. The DVCPRO-HD looks fine rendered at HDV 720 60i (which would require rendering the HDV smaller) and a bit fuzzy at HDV 1080i. I’d rather not render down from DVCPRO-HD and cut at HDV but the only solution I can think of is to output the HDV 1080i to either HDCAM or DVCPRO HD (both would require renting a deck which I’d like to avoid if possible) and redigitizing at DVCPRO-HD.
    I’m hoping someone has a better solution.
    Tony Alznauer
    Post Production Supervisor
    Blink Digital-Santa Monica
    Earthworm replied 20 years, 1 month ago 4 Members · 4 Replies
  • Travis Ballstadt
    August 3, 2006 at 3:18 am
    Have you tried MPEG Streamclip to do a conversion instead of using FCP? Might be worth a shot.
    https://www.squared5.com/
    Also, not sure if it would work, but if you have an HD capture card, can you capture the analog out of the HDV as DVCProHD?
    travis ballstadt
    http://www.thrillcateditorial.com
  • Mark Maness
    August 3, 2006 at 3:21 pm
    I would suggest that you look into purchasing an AJA HD10AVA for you HDV machine, and that way you can digitize your footage at any resolution in any codec. I assume you have an HD capture card in your system. Cross-converting and changing i to p is always problematic in FCP unless you can digitze your footage in the same codec.
    As for the price of the AJA unit, B&H sells it for just under $1000. That’s the price of a rental deck for one day usually.
    I will never run my HDV deck in HDV in FCP. The workflow is awful and extremely slow.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Gary Adcock
    August 3, 2006 at 4:12 pm
    [Wayne Carey] ” I assume you have an HD capture card in your system. Cross-converting and changing i to p is always problematic in FCP unless you can digitze your footage in the same codec.”
    Wayne makes a good point
    by brining in the HDV footage as 1080 DVCPROHD then the HDV footage will be easier to handle. I would recommend cutting the 2 types of footage separately then only rendering out to your final file. it is easier to make progressive footage interlaced than making interlaced footage progressive.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    My DVD’s are available @
    https://www.rastervector.com/dvd/dvd.html
  • Earthworm
    August 3, 2006 at 5:45 pm
    I’m purchasing an AJA HD10AVA. I didnt know it existed.
    $1000 is a small price to pay to avoid editing HDV…
    Thanks, Wayne.
    -Tony Alznauer
