Activity Forums Apple Final Cut Pro Legacy Need Help. Clip snaps to end on timeline? How to turn it off
  • Need Help. Clip snaps to end on timeline? How to turn it off
    Posted by Ed Stevens on October 14, 2005 at 2:05 pm
    My SYSTEM
    MAC dual G5 2.5 gig. 4.5 gb RAM. OS 10.3.8
    Blackmagic Decklink Extreme card v4.8b
    FCP 4.5 production Suite
    500GB G-Raid Firewire800
    Decks = Beta-SP, DVCpro, DigiBeta.
    Audio Mix = Mackie 1604 VLZpro
    I believe I have the stock display card
    Panasonic AJD-230H DVCpro deck
    2 questions.
    When I bring in a clip to the timeline, say a long clip of 40 sec.) it snaps to the end of the clip . How is this turned off?
    Thanks in advance to ALL
    ED
    Jeff Carpenter replied 20 years, 11 months ago 3 Members · 2 Replies
  • Ivan
    October 14, 2005 at 2:19 pm
    If it’s what i think…Just press N…
    Neo
  • Jeff Carpenter
    October 14, 2005 at 2:25 pm
    Ivan is correct that the “N” key turns off snapping, but I’m not positive that’s what you’re talking about. Snapping is when you drag things around the timeline they will jump to the edges of other things. “N” will toggle that feature.
    But it kind of sounds to me, Ed, like you’re talking about when you drop a long clip on the timeline and the playhead jumps to the end of that clip. If that is what you’re talking about then no, you can’t turn it off. But you CAN hit the up-arrow key to move you to the start of a clip. So just drop it and then hit “up.” It’s not quite as good as turning that off, but it’s the next best thing.
