Activity › Forums › Maxon Cinema 4D › Need Help Animating Ready CAD Conveyor Belt
  • Need Help Animating Ready CAD Conveyor Belt
    Posted by David Alcantara on July 1, 2021 at 5:45 pm
    I have cad file of conveyor belt including details in the belt with 2 gears at each end, I want to animate it with XPresso.
    All the tutorials available they animate the spline or cloner parameter, but What I have is ready CAD file of a Conveyor Belt, so I cannot use cloner or spline wrap. I want to animate the ready cad file belt.
    How to do it?
    David Alcantara replied 5 years, 3 months ago 2 Members · 2 Replies
  • Andy Kiernan
    July 2, 2021 at 11:08 am
    Hi David,
    You can perhaps split up the cad model for use with cloner/ wrap.
    Assuming the conveyor belt is made of multiple repeating sections, you can select one section (polygon mode, then select one poly in that section and hit u then w keys to select connected, or select them manually) then run the split command. this will copy the selection to a new object and leave the selection in the original. Then you can clone them or copy them in a line and spline wrap. You can do this to the cogs also so they can be animated too.
    Hope this is of some help.
    AK
  • David Alcantara
    July 2, 2021 at 11:16 am
    Thank you so much, really helped a lot!
