Activity › Forums › Adobe After Effects Expressions › Need help adding Z space to this connector expression
  • Need help adding Z space to this connector expression
    Posted by Afshar13 on March 7, 2007 at 9:14 pm
    Hi
    I just finished Adobe Total Training dvd set and i found a Connector expression (by Fred Lewis for a line between two points) can any one fix this to work between 2 points in 3d space? you guys rule!
    Connector By Fred Lewis
    These Expressioss can be used to make a connector that stretches like a rubber band between two layers, which by default are named
    Afshar13 replied 19 years, 6 months ago 3 Members · 6 Replies
  • Filip Vandueren
    March 8, 2007 at 1:54 am
    I changed your expressions to this:
    / apply this Expression to the Connector layer’s Position parameter
    // set follow1 below to the name of the first layer to follow
    follow1 = “End 1”
    this_comp.layer(follow1).position
    ________________
    // apply this Expression to Connector layer’s ORIENTATION parameter
    // set follow2 below to the name of second layer to follow
    follow2 = “End 2”
    lookAt(position,this_comp.layer(follow2).position);
    ________________
    // apply this Expression to Connector layer’s Scale parameter
    follow2 = “End 2”
    stretch = 100 * (length(position,this_comp.layer(follow2).position) / this.width);
    [stretch,scale[1], scale[2]];
    Set Y Rotation to -90 degrees
    I changed the Stretch expression so it works for layers that are not 100px wide.
    Kown Issue:
    – the line can get pretty thin at certain positions: it connects the two objects perfectly, but it doesn’t automatically show it’s flattest widest side to the camera.
    – this only seems to work in Comps that have Square Pixel aspect ratio.
  • Afshar13
    March 8, 2007 at 3:11 am
    Your the man!!! Thanks i will plug and play…
  • Afshar13
    March 8, 2007 at 4:00 am
    that seemed to do it accept where my connector touches my second element the connector does’nt quite touch it. There is a little gap between it and the element. I tried simply increasing the size of the connector but no joy. Any final sugestions for this AE newbe…
    thanks again!
  • Filip Vandueren
    March 8, 2007 at 4:05 am
    Is it a solid or a vector layer ?
    Perhaps toggling on the “Rasterize Continously” switch will help, as It could be an interpolation-stretch error from the soft edge.
    Also make sure the AnchorPoint’s left is exactly at 0
  • Mylenium
    March 8, 2007 at 11:11 am
    Most likely it’s the filtering of the 3D layers. You could only minimize this by using much longer layers, so instead of 100 px length use 10000 or so.
    Mylenium
    [Pour Myl
  • Afshar13
    March 8, 2007 at 9:55 pm
    Its a vector mask, i will try these sugestions
    Thank you gentlemen.
