Activity Forums Maxon Cinema 4D Need Hardware Advice
  • Need Hardware Advice
    Posted by Jacob Rice on November 15, 2012 at 8:26 pm
    My boss is going to put me through classes to learn Cinema 4D and I need to upgrade my computer to be able to handle it. Can you guys look at my computer specs and make suggestions on what I should get. The Cinema 4D is pretty unspecific about what I need so I was looking for a little help.
    I know I need to switch to 64 Bit, and I know I need to upgrade and get a Video Card and more ram, I’m just not well versed on video cards so I am not sure which one I need.
    Florin Cosmin replied 13 years, 9 months ago 2 Members · 1 Reply
  • Florin Cosmin
    November 17, 2012 at 7:25 pm
    you should say your budget…
    Cheaper version:
    i7 3770k (almost 8 in cinebench and 10 with OC) + 16/32gb ram + SSD
    The expensive one
    I7 3930X (10 in cinebench and 13 with OC) + 16/32gb ram + SSD
    About videocard, you don`t need an expensive one. C4d is using the CPU for rendering, not the gpu… If you really want one you could try the nvidia 640 or above.
    Florin
