Activity Forums Sony Cameras Need FCP to use XDCAM transfer?
  • Need FCP to use XDCAM transfer?
    Posted by Suzan Beraza on February 2, 2009 at 10:13 pm
    Friends in moo,
    I have the Sony PMW-EX1 and use XDCAM Transfer software to make quicktimes and import my clips into FCP. I am working on a doc, and one of my camera operators has a laptop but does not have FCP. He wants to be able to make quicktimes for me and for other clients. Can he do this without FCP? I loaded the software on his computer and got quite a few missing codecs and a note at the bottom saying they were included in last version of FCP.
    So to sum up, 1) Can I load those missing codecs from another source, and 2) Can XDCAM Transfer be used to make quicktimes without having FCP.
    Much thanks,
    Suzan Beraza
    REEL Thing Productions
    Craig Seeman replied 16 years, 11 months ago 3 Members · 3 Replies
  • Craig Seeman
    February 3, 2009 at 12:23 am
    Preferences/General tab
    XDCAM Transfer user manual page 37:
    Codecs:
    • Import clips with no installed codec check box
    Specifies whether to import clips even when the codec for the original material of those clips is not installed on your computer.
    graphic under than in manual
    Codecs: Import clips with no installed codec
    If the appropriate codecs are not installed you will still be able to import but not view or edit the imported movies on this computer.
  • Diego Delavega
    October 4, 2009 at 11:14 am
    hi to all
    is it possible to a recive a codec xdcam to transfer a file directly to final cut
    many thanks
    diego
  • Craig Seeman
    October 4, 2009 at 1:19 pm
    The short answer is yes.
    The longer answer is you need to know if you have or can get what you need to read the codec.
    XDCAM EX can be BPAV/MP4, MOV, MXF.
    XDCAM is usually MXF.
    You may need to rewrap to MOV if it’s not in that format or you may need a plugin to import directly.
    I’d suggest you be on at least FCP 6.0.2 or higher.
