Activity Forums VEGAS Pro Need explanation of Alpha Channel Options within SVP
  • Need explanation of Alpha Channel Options within SVP
    Posted by Ron Whitaker on April 22, 2012 at 4:45 am
    I got my alpha channel question answered and it’s now working.
    Thanks.
    A question I now have is: when you click on the properties of an element, within the Media tab, you have the option to set your Alpha Channel.
    What is the difference between the different settings (ie, Undefined, Straight (unmatted), Premultiplied, Premultiplied (dirty)), and in which situations would you select each of these?
    Thank you.
    John Rofrano replied 14 years, 4 months ago 3 Members · 2 Replies
  • Steve Rhoden
    April 22, 2012 at 11:46 am
    In a brief nutshell the straight unmatted and
    premultiplied are the two most important ones. Basically,
    there is no hard or fast rules where either is concerned, because most
    of the time it will depend on your perception as to which of the
    two gives you a cleaner matte when selected (however premultipled
    are normally cleaner), and this is due to how the media was
    originally processed.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • John Rofrano
    April 22, 2012 at 2:14 pm
    [Ron Whitaker] “What is the difference between the different settings (ie, Undefined, Straight (unmatted), Premultiplied, Premultiplied (dirty)), and in which situations would you select each of these?”
    As Steve said, you need to match the alpha channel to the way the original was processed. Most alpha channels like those in PNG files are straight(unmatted). Sometimes when working with particles in a 3D program, using an alpha that is premultiplied with black with help the small particles stand out better. In this case, you can tell Vegas that you premultiplied the alpha and it will adjust for it. The thing to remember is that you should match the alpha processing with the original footage alpha processing.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
