Activity Forums Apple Final Cut Pro Legacy Need Cinema Tools workflow directions
  • Need Cinema Tools workflow directions
    Posted by Juan Carlos aguirre on February 3, 2007 at 9:33 pm
    I’m cuting a short that was shoot in 35mm, Dailes are transfer to Beta SP at 29,97, and also have the flex files. So:
    I import the flex files to Final Cut and Cinema Toos, and have a batch list. The questions is.. Which frame rate is use to digitize the tapes? Do I need to use 29.97 and then reverse telecine ? or Digitize stright to 23.98. I’m consufe about it.. But for sure I need to deliver a cut list for the negative.
    Many thanks
    Jeremy Garchow replied 19 years, 7 months ago 3 Members · 2 Replies
  • Shane Ross
    February 4, 2007 at 1:26 am
    If you are going to be cutting the negative, then capture at 29.97, and reverse telecine. But do make sure that you involve Cinema Tools in this process. Looks like you are, so…good job.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    February 4, 2007 at 1:34 am
    The Cinema Tools manual/help file can explain all of this to you. It’s a short manual so don’t be scared.
    Jeremy
