Activity Forums VEGAS Pro need assistance with merging
  • need assistance with merging
    Posted by Roger Huang on August 5, 2010 at 1:08 pm
    Hello.
    I have 2 .avi files. Let’s call them A and B. They both have the same format, etc.
    Can I use Vegas to combine A and B into 1 file?
    I want the single file to be a simple merge of A’s and B’s content. No compression. No enhancements. The combined file should have the same format and characteristics of A and B.
    Is there a simple way to do this without having to set a number of parameters in Vegas?
    I used to use VirtualDub to do this. It was as simple as first opening A. Then selecting [File / Append AVI} and then selecting B. Then doing [File / Save As].
    The new combine file’s size would equal the combined file sizes of A and B.
    Is there just as simple a process in Vegas?
    John Rofrano replied 16 years, 1 month ago 3 Members · 2 Replies
  • Danny Hays
    August 5, 2010 at 10:43 pm
    Here’s a free app that will join clips together, as well as split into smaller pieces.
    https://www.filesplitter.org/
    Hope this helps, Danny Hays
  • John Rofrano
    August 5, 2010 at 11:05 pm
    Nope. The file would have to be a format that Vegas knows how to “smart render” and then you’d have to know the proper template to use. It’s not easy and it’s not what Vegas was designed to do.
    I recommend you keep doing it this way. You know, a carpenter doesn’t go to work with one tool in their pouch. Use the right tool for the job. In this case it’s VirtualDub.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
