Activity › Forums › Maxon Cinema 4D › Need assistance with dynamic wire
  • Need assistance with dynamic wire
    Posted by Tony Barone on August 4, 2017 at 12:45 pm
    I’m having trouble trying to figure out how to animate a wire. I need to show a bulb being removed, and its connecting wire passing through the object the bulb is mounted in. The other part of my problem is I then need to show it in reverse, threading the wire back through the opening.
    I could just render it being removed and then reverse it though, that is, if I could figure out the first part.
    Any help is greatly appreciated.
    Project File attached.
    11571_wire.zip
    Tony Barone replied 9 years, 1 month ago 2 Members · 2 Replies
  • Cassius Marques
    August 4, 2017 at 1:47 pm
    Instead of a sweep nurbs, create a cylinder object and use the spline wrap deformer. That way you can animate it’s position on the spline
    Cassius Marques
    http://www.zapfilmes.com
  • Tony Barone
    August 4, 2017 at 8:09 pm
    Thanks for your help, that basically does what I want!
