Activity › Forums › Maxon Cinema 4D › Need assistance converting an object
  • Need assistance converting an object
    Posted by David Altman on November 13, 2017 at 7:29 pm
    I recently downloaded a 3d cupcake in the .C4D format. I then downloaded the trial version of Cinema 4D, registered it, and converted the object to a Wavefront .OBJ … I also tried .FBX. However, when I try to import the .OBJ into Maya, it gives me an error on line 0 of the file. I really need to get this object into Maya. Can anyone help me with this??
    Adam Trachtenberg replied 8 years, 10 months ago 3 Members · 6 Replies
  • Adam Trachtenberg
    November 14, 2017 at 5:01 pm
    If you attach the file I’ll give it a shot.
  • David Altman
    November 16, 2017 at 12:29 pm
    I already posted the file – but it seems like it’s not visible. I’ll try again. No. It’s still doing weird things. Their system doesn’t work very well. The file is posted at https://f1.creativecow.net/11851/cupcake-c4d. Thanks!
  • Jim Scott
    November 16, 2017 at 4:27 pm
    In case Adam doesn’t see your post for awhile, here’s the obj file exported from C4D:
    11870_cupcake.obj.zip
  • Adam Trachtenberg
    November 17, 2017 at 12:16 am
    And in case Obj doesn’t work again, here it is in Fbx format:
    11871_11851cupcake.fbx.zip
  • David Altman
    November 17, 2017 at 3:32 am
    The .obj file gives the error “line 0: Error reading file.” The .fbx file says “not enough parameters.” These are the same errors I got when converting it myself.
  • Adam Trachtenberg
    November 20, 2017 at 6:09 pm
    I don’t know what to tell you. I don’t have Maya but I know people frequently go back and forth using .obj and .fbx.
