Activity › Forums › Apple Final Cut Pro › Need a way to rapidly show 50+ images within 20-30 seconds
  • Need a way to rapidly show 50+ images within 20-30 seconds
    Posted by Jeff Swearingen on May 10, 2017 at 4:16 am
    Hello — I can’t put my finger on the term for this. But essentially I need to drop in a series of 50+ stills into an FCPX project and have them quickly cycle through around 0.5 sec each.
    Any suggestions to make this efficient?
    Jeff
    Jeff Swearingen replied 9 years, 4 months ago 3 Members · 5 Replies
  • Helgi Thor
    May 10, 2017 at 1:35 pm
    Select all the stills in the browser, hit E to put them in the project, select all, hit ctrl-D, enter 15 (or 12 if it’s a 24fps project) hit Enter.
    Helgi Thor
    Editor
    Fortaleza
    Brazil
  • Helgi Thor
    May 10, 2017 at 1:40 pm
    And if you need to do this regularly you can change the default duration of stills in the preferences.
    Helgi Thor
    Editor
    Fortaleza
    Brazil
  • Jeff Swearingen
    May 12, 2017 at 11:09 am
    Perfect. Thank you!
  • Eric Santiago
    May 15, 2017 at 5:40 pm
    If your lazy place in a CC and use Speed controls.
  • Jeff Swearingen
    May 23, 2017 at 6:07 am
    Thanks for the responses. Using Command-D and the duration was the easiest.
