Activity Forums Apple Final Cut Pro Legacy need a quicker way to skew text
  • need a quicker way to skew text
    Posted by Roli Rivelino on March 9, 2010 at 4:31 pm
    Is there a quicker way to skew my text than going into the distort parameters in the motion tab and entering values?
    I’ve tried various combinations of buttons in the image and wireframe view but can’t seem to get it to do anything other than change size or rotate.
    many thanks
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Stephen Smith replied 16 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • John Fishback
    March 9, 2010 at 4:48 pm
    One way to deal with easily applying distort to a clip is Paste Attributes. Skew the first clip the way you want, then copy it. Make your next text clip, then Paste Attributes and check Distort. Or, just copy the clip, paste it where you want in the timeline and then change the text. And, I think Boris Title 3D has a slew parameter.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Roli Rivelino
    March 9, 2010 at 5:18 pm
    I don’t think that method helps me, let me explain a little more, I have a shot of a building which should have some lettering on it and so I want to skew the lettering so it looks real.
    But entering numbers isn’t really working for me so I just want to drag it around till it looks right, is Boris Title 3D an effect within Final Cut or something separate?
    Do you think I should be doing this in motion anyway?
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • John Fishback
    March 9, 2010 at 5:33 pm
    Boris Title 3D is a Generator in FCP. It’s probably easier to work with for your purpose than the distort settings as you’ll see the result as you move the control. But, if you’re familiar with Motion that’d work fine as well. You might want to add a bit of blur or noise to the text so it looks a bit more “real” when composited on the building. If your shot is moving, then tracking in Motion will be better.
    John
  • Stephen Smith
    March 9, 2010 at 5:43 pm
    I would create the text in Motion. It will let you skew it or rotate it any way you want. In my opinion the rotate feature in FCP doesn’t look very good, it will bend stuff funny sometimes.
    Utah Video Productions
    Check out my Motion Tutorials
  • John Fishback
    March 9, 2010 at 6:29 pm
    If you need a Motion tutorial, checkout Stephen’s. I’m a long time AfterFX user, but wanted to quickly get up to speed in Motion. His excellent tutorial did the trick.
    John
  • Roli Rivelino
    March 10, 2010 at 8:57 am
    Cool, I will do that, many thanks guys.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Stephen Smith
    March 10, 2010 at 4:05 pm
    Happy to help Roli. Thanks for the kind words John. Best of luck.
