Activity › Forums › Adobe Audition › Need a little help
  • Need a little help
    Posted by Wolf 10 on November 10, 2007 at 1:34 pm
    When I record something in one of the tracks it records fine, lets call this track 1. Now when I go to record in a different track that’s at the same time as track 1 but in a different track of course, the track I’m currently recording just records the one from track 1 for some reason. Any ideas on how to fix this?
    -Mike-
    Willie Toth replied 18 years, 10 months ago 2 Members · 1 Reply
  • Willie Toth
    November 10, 2007 at 3:29 pm
    Mike,
    What version are you using? Are you recording through a mixing board? If you are using a mixing board I think it is the likely source of your loop … If you aren’t then you have something set wrong in your track mixer causing the problem check for proper routing … WILLIE
