Activity › Forums › Blackmagic Design › Need a good inexpensive audio monitoring solution (SPDIF?)
  • Need a good inexpensive audio monitoring solution (SPDIF?)
    Posted by Peter Corbett on December 15, 2007 at 4:21 am
    I’ve been using the ASIO drivers to monitor audio from my Decklink HD Extreme, but I’m getting choppy audio payback on Vista 64 and Premiere. I notice the HD Extreme doesn’t have a dedicated SPDIF RCA monitoring output. Is the AES output the same (technically)?
    Plus I’m thinking of buying either the Edirol 15’s or Behringer MS40’s for monitoring, although I’ve head mixed reports about both. Perhaps a simple domestic amp with coaxial digital in may be the answer?
    Any advice or expriences gtratefully accpted.
    Peter
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
    Michael Yecies replied 18 years, 8 months ago 6 Members · 8 Replies
  • 8 Replies
  • Aristides Tiropolis
    December 15, 2007 at 6:09 pm
    I’ve been having the same issues and I’m using the decklink balanced outputs for monitoring on my HS50’s in conjuction with the Audigy, my verdict is that the ASIO driver in the Decklink, besides incomplete and buggy is only useful for capturing, I say this because in this website they state: “With support for Core Audio on Mac OS X
    December 15, 2007 at 6:11 pm
    Forgot to mention the card, it’s called the julia
    https://www.esi-audio.com/products/julia/
  • Bob Zelin
    December 16, 2007 at 6:47 pm
    this is the cheapest answer, and also the most flexible.
    Buy the Behringer Ultramatch Pro 2496. It’s $129 US, and it will convert anything to anything. This way, you don’t have to buy any new speakers/amplifiers, and if you change in the future, you can accomodate anything you want.
    Bob Zelin
  • Jimmy Brunger
    December 17, 2007 at 8:59 am
    I use Roland DS-5 digital monitors via SPDIF with my Decklink Pro and they work a dream. Not sure about SPDIF outputs on Extreme cards, but the DS-5’s have a tonnes of outputs both digital and analogue, so would be worth looking into I reckon.
    Good luck and let me know how you get on with your monitoring on the extreme…I was going to purchase a HD Extreme and was going to use the same monitors, but not if it’s ‘choppy’!
    *Production Studio Premium CS2 / *Combustion 3 / Mocha v1
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB boot/80GB media/600GB RAID-0
  • Peter Corbett
    December 17, 2007 at 11:09 am
    I went el cheapo and ordered a pair of Behringer MS40’s. I’ll give them a go to get me through Christmas. The Rolands look very nice, but a bit pricey. Thankyou everyone for the advice. Another example of the Cow’s value and friendliness.
    Peter
    Peter Corbett
  • Jimmy Brunger
    December 17, 2007 at 12:01 pm
    The Rolands weren’t much more than the Behringers when I last checked…something like
  • Justin Ferar
    December 18, 2007 at 8:58 pm
    I can’t say enough about this thing (Ultramatch Pro 2496). I use it in my FCP setup- it just works. Best value I think I’ve ever seen.
  • Michael Yecies
    January 10, 2008 at 5:59 pm
    The behringer box has a great spec. I’m looking for a way to get 8-channels of analog monitoring from either HD/SD SDI or AES, aside from installing 4 of these boxes. Any suggestions? Price is a factor.
    Thanks.
