Activity Forums Avid Media Composer Need 4K storage suggestions Windows users
  • Need 4K storage suggestions Windows users
    Posted by Kenneth Maultsby on August 25, 2019 at 11:23 pm
    I am about to start my first 4K project and one of my hard drive crash on raid 0 system. I was able to get older projects off of it “lucky” Media was backup anyway. So I began Transcode my 4K footage from my Drobo to my 500GB SSD media drive DNXHR SQ and the driver wasn’t big enough. I have order a 1TB SSD but if change my RockStor to a Raid 5 will it be fast enough for 4K? I would like to here from others here or suggestions what you use as a media drive for 4K DNXHR.
    OS Windows 10
    CPU AMD Ryzen 7 1700X 3.70 GHz
    Memory 32 gb
    Hard drives
    C: SSD OS and Programs
    E: Media SSD 500GB
    F: 2 TB Documents and other programs
    G: Drobo 6TB photos and videos
    H: SSD 500 gb Cache drive
    I: RockStor Raid 0 1×4 TB (Crashed)
    OS Windows 10
    Memory 32 gb
    Hard drives
    Kenneth Maultsby replied 7 years ago 2 Members · 2 Replies
  • Pat Horridge
    August 26, 2019 at 8:22 am
    You need to do the maths.
    What’s the sustained data rate of your Raid 5 proposed setup (best to configure it and test. Or check manufacturers stated spec)
    What’s the data rate of you media.
    How many real time streams will you need (at least 2 but possibly more if you are doing effects)
    Add 20% or so overhead.
    I’d not use Raid 5 Raid 1 or 10
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
  • Kenneth Maultsby
    August 27, 2019 at 8:44 am
    What are using?
    OS Windows 10 CPU AMD Ryzen 7 1700X 3.70 GHz
    Memory 32 gb
    Hard drives C: SSD OS and Programs
