Activity Forums VEGAS Pro need 30 seconds of 22gb m2ts file
  • need 30 seconds of 22gb m2ts file
    Posted by Rick Barnett on May 30, 2014 at 2:04 am
    I rarely use Sony Vegas anymore. I am trying to extract 30 seconds of this home made video I have on blu-ray. I cant figure it out. I use Sony Sound Forge ALL THE TIME! But Vegas simply wont select between two markers and extract. Unless I am missing something. I then will convert to .mov so I can make a animated gif. Thanks for any help guys! regards Rick
    John Rofrano replied 11 years, 11 months ago 2 Members · 1 Reply
  • John Rofrano
    June 2, 2014 at 4:51 am
    [Rick Barnett] “Vegas simply wont select between two markers and extract. Unless I am missing something. I then will convert to .mov so I can make a animated gif. Thanks for any help guys!”
    Make a timeline selection for the duration that you want and render it QuickTime using the Render loop region only option. That will give you just the section to looped on the timeline.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
