Activity Forums Adobe After Effects Expressions nearestKey from other layer
  • nearestKey from other layer
    Posted by Jano Sempere on December 19, 2014 at 7:57 pm
    Hello.
    I usually use:
    d = Math.abs(time – nearestKey(time).time);
    easeOut(d, 0, .1, 100, 0)
    Which retrieves somthing like 3 keyframes with just one. This works fine working in a layer.
    I want to use a layer reference (A), to this layer will be linked 2 solids 1 and 2.
    Solid 1 will take value information form the keyframes, as usual (Just picking with pickwhip)
    Solid 2 Just take the position of keyframe to change it’s opacity like a camera flash.
    I’ve tried many and many expressions, but I can’t solve.
    d = Math.abs(time - nearestKey(time).time);
    Jano Sempere replied 11 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 20, 2014 at 12:37 am
    You didn’t mention which Layer A property you wanted to respond to, so this assumes Opacity (just change the first line if that’s not correct):
    // solid 2’s opacity expression might look like this
    prop = thisComp.layer(“Layer A”).transform.opacity;
    d = Math.abs(time – prop.nearestKey(time).time);
    Dan
  • Jano Sempere
    December 20, 2014 at 8:28 am
    Hello Dan.
    You are a genius, and you are right, sorry, Layer A is a control layer, and the property to change is a checkbox.
    Expression works perfectly, I just modified the first line and voilá, I think I didn’t defined well the first variable and of course my expression didn’t works.
    Best regards
    Jano.
    Motiongrapher at cinestorm.es
