Activity › Forums › Adobe Illustrator › Neagtive / Invert in Iluustrator
  • Neagtive / Invert in Iluustrator
    Posted by Roger Burton on March 12, 2007 at 2:40 pm
    Hi chaps … I have a logo in illustrator that prints blue on white (this explanation of my problem is probably going to be a bit tiresome) the logo is a boat so stripes down the side and portholes etc are blue (ie the ‘dark’ areas of the image and the main bits of the boat (which are white) are represented by the white paper it’s printed on. Well I want to print the logo on some blue Tshirts … I don’t just want to print what was blue ink as white ink on a blue shirt because the boat image will be, in effect, negative. Can I, in illustrator, kind of, invert my objects ie the objects become the background and the background becomes an object …. I think.
    many thanks for your time … Roger
    Roger Burton replied 19 years, 6 months ago 2 Members · 2 Replies
  • Mike Gondek
    March 12, 2007 at 7:26 pm
    If the file was built using global or spot color swatches you could correct this quickly in the swatches palete with a couple of alt drags. Probably is nto built with gloabl colros, but the solution is ismlpe nonetheless.
    Make 2 swatches (Blue, White) on you swatches palette and choose spot
    Select a white fill
    select >> same >> fill color
    click on the blue swatch
    Select on of your old blue colors
    click on the white swatch
    If you have stroke, repeat the process for them.
    Now that the colors are built as spot, you can in the future just t doubleclick the swatch in the swatches palette and change it there to whatever you want. Read your help on merging swatches, very bloody good info every illustrator user can benefit from.
  • Roger Burton
    March 13, 2007 at 11:59 am
    Thanks Mike …. good of you to take the time.
    Roger
