Activity › Forums › Apple Final Cut Pro Legacy › NDF DF warning capturing DVCAM NTSC
  • NDF DF warning capturing DVCAM NTSC
    Posted by Brenda Goldstein on May 21, 2010 at 7:43 pm
    Hello all,
    I am having a problem with the following warning:
    “you are about to capture NDF media from a device currently detecting or configured for DF media.”
    (running fcp 6.0.6 on Macbookpro with OS X 10.5.8)
    I am working from flx files from cinema tools (35mm, NDF xfer to DVCAM) which I have imported to be digitized. I am using a sony pd 150 to capture the clips. For some reason FCP is reading that the PD-150 sending a DF signal. I have reset the camera tc. The only way i don’t get the warning is if I go in to cinema tools and resave each clip as DF. Then import–but that is only a temp fix, production is to be finished on film, and I am worried about sync issues.
    I have double checked with the lab.
    What is going on?
    Brenda Goldstein replied 16 years, 4 months ago 2 Members · 3 Replies
  • John Pale
    May 21, 2010 at 8:51 pm
    Try playing the tape a bit before attempting to batch capture. The camera probably is outputting a drop frame signal by default when nothing is detected. When you actually play the tape it gets a taste of that non-drop TC, it will then know what to do. There may be a setting somewhere to make it output NDF by default, also.
  • Brenda Goldstein
    May 22, 2010 at 4:09 pm
    OK! I will try that tomorrow and let you know how it goes.
    Thanks so much
    .b
  • Brenda Goldstein
    May 23, 2010 at 7:17 pm
    Hi John,
    Sad to say this did not work either. still got the warning…
    BTW, the camera was set to NDF in VCR mode.
    Any other suggestions?
    Brenda
