Activity Forums Adobe Premiere Pro Naughty junior editor!
  • Naughty junior editor!
    Posted by Dylan Hargreaves on February 14, 2012 at 11:27 am
    Hey folks,
    My naughty junior editor has chucked some b-roll into an edit with no atmos. In FCP, frame matching the clip in the sequence with the original in the browser so you can re-edit the clip with audio is a cinch. But not so it seems in PPro.
    The Reveal Original command brings up the clip in the browser from the beginning, not from the frame you want. And unlike FCP, it doesn’t seem to keep the old edit points so I can’t quickly determine the correct frame.
    Unless that is, there’s a way to do it I don’t know about. Which is certainly a possibility. Anybody?
    Cheers!
    Dylan Hargreaves replied 14 years, 7 months ago 2 Members · 2 Replies
  • Eric Jurgenson
    February 14, 2012 at 2:18 pm
    Dylan,
    With the CTI positioned at the desired sync point in the timeline, load the source scene into the source viewer. Select sequence-> match frame, or type “M” (hot key). (If there are multiple tracks, make sure the desired track is highlighted).
  • Dylan Hargreaves
    February 16, 2012 at 4:43 pm
    Too easy! Thought there had to be a way!
    Thanks, Eric
