Activity › Forums › Apple Final Cut Pro Legacy › Nattress NTSC->PAL w/ 4 audio tracks
  • Nattress NTSC->PAL w/ 4 audio tracks
    Posted by Pierre-luc Pare on August 20, 2007 at 9:16 pm
    Anyone can tell how to keep 4 audio tracks when nesting a NTSC clip (Uncompressed 8-bit from DigiBeta) to convert to PAL (Uncompressed 8-bit) with Nattress G Converter ? I need the 4 audio tracks to then output to PAL DigiBeta.
    If anyone can answer ASAP.
    Thanks a lot !
    Pete
    Graeme Nattress replied 19 years, 1 month ago 3 Members · 2 Replies
  • Rich Rubasch
    August 21, 2007 at 12:34 am
    Can’t you just nest the video so that you can use the converter, then edit in the audio tracks? There should be no problem just editing in the audio only from the NTSC sequence into the new PAL sequence.
    Rich Rubasch
    Tilt Media
  • Graeme Nattress
    August 21, 2007 at 3:47 am
    You can just nest the video and not nest the audio tracks. As long as the NTSC audio is put on the PAL timeline, it should still sync.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
