Activity › Forums › Adobe Premiere Pro › native RED editing
native RED editing
Posted by Rick Van den berg on March 7, 2013 at 5:09 pmHi,
I’m currently switching from final cut 7 to premiere. i was told it’s possible to edit RED files straight away. well, i can import the files, but its playing back very choppy. I’m running a mac with a 2*2,8 GHZ quad core with 16 GB RAM and an ATI HD 5770 and i got a red rocket card installed. i checked if the red rocket is active and i just re-installed the whole mac with only premiere installed yet. but its still laggy when playing red files. though i can play it on 1/16th. but still not perfect.
i watched a couple of tutorials and i figured it should play very smooth even if you don’t have the fastest computer on earth. i can of course just convert everything to prores or whatever, like i did with FCP7 but editing in RED will definitely boost up the whole process.
so what am i doing wrong?
thanks in advance.
Tom Daigon replied 13 years, 6 months ago 6 Members · 15 Replies -
Tom Daigon
March 7, 2013 at 5:17 pmChange your right screen (Program Monitor) to 1/2 resolution. See if that helps.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=DxPrG3WUyz8
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
Rick Van den berg
March 7, 2013 at 5:23 pmdoesn’t help, actually that makes it even worse. when i press play i only hear the audio track and only when i stop it it updates the video. but thats only with red rocket activated, when i disable it, it works ”properly” again. but only choppy.. pretty weird
Angelo Lorenzo
March 7, 2013 at 5:32 pmA few things:
1) Make sure your RED importer plugin is up to date https://labs.adobe.com/technologies/redepic_importer/
2) Make sure your Red Rocket drivers and firmware are up to date
3) Make sure your Red Rocket is actually active. With a RED clip loaded in your bin, right click and select “source settings” scroll down and look at the settings. If the Rocket icon is lit in Redcine X (assuming you have it open at the same time) then Redcine X has reserved the card and Premiere isn’t using it. Only one program can use a rocket card at one time.
Curious, what is your hard drive setup?
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Rick Van den berg
March 7, 2013 at 5:50 pmIm sure the red importer plugin / rocket firmware are up to date and no other app is using it.
i did everything from an external hard disk via a firewire 800 cable.
i copied a single clip to my desktop just to try out the difference, but nothing noticeable happened. frustrating..no chance it’s because of ati instead of nvidia? i know my gfx card is an issue @ davinci resolve.
Angelo Lorenzo
March 7, 2013 at 8:26 pmWell the Adobe Mercury Playback Engine can work in three modes: CPU, CUDA, and OpenCL. Now your ATI/AMD card isn’t officially supported but many GPUs can be added to a text file with in Premiere Pro’s program files to trigger Premiere to utilize them but this may not the best solution. Have you done this modification?
Are you playing the RED files in a native sized timeline (2k, 4k) or are you scaling them down in a program sized timeline like 1080 or 720. The scaling can add additional CPU overhead… which shouldn’t be an issue with your dual CPU setup but I still have to mention it.
How is playback in Redcine-X? Smooth?
What does your process manager look like in terms of CPU/RAM usage when you play the file in Redcine-X vs. Premiere?
I have a Red Rocket in my PC setup and I get smooth playback in every application that supports it at full quality.
Angelo Lorenzo
March 7, 2013 at 8:29 pmIn Premiere, another thing to look at is do you have your reference monitor up at the same time as your program monitor? The reference monitor is usually a clone of the program monitor that many people switch to viewing the video scopes with. If it’s ganged to playback with the Program Monitor it can degrade performance like playback and timeline scrubbing.
Chris Borjis
March 7, 2013 at 10:48 pm[Rick van den Berg] “i did everything from an external hard disk via a firewire 800 cable.
i copied a single clip to my desktop just to try out the difference, but nothing noticeable happened. frustrating..”for Red editing you really should have some sort of RAID if smooth playback is expected.
Angelo Lorenzo
March 7, 2013 at 10:55 pmI beg to differ, in certain cases. At a single stream of video, 4K performance off firewire is fine for the most part, internal single drives are more than usable. For multicam or any types of stacked editing I would look at RAID.
I don’t think the hard drive is the bottleneck for stutter on a single clip.
USB2 I would have worried.
Eric Sanders
March 8, 2013 at 2:09 amI have found that FW800 drives can have the issue of the controller resetting a bunch – as a test, if you work with say one of your clips on an internal drive rather than your FW800, does it change the behavior?
-EricS
