Activity Forums Adobe Premiere Pro native RED editing
  • Angelo Lorenzo
    March 8, 2013 at 2:18 am
    That’s fine, I’m disagreeing with you in context of the OP’s troubleshooting. SATA throughput is more than adequate even with the least compressed REDCODE 3:1 for single track edits. Firewire also has adequate throughput for single track edits for REDCODE 6:1 or more compressed (as long as the drive is full-sized, 5400rpm or mini drives typically can’t push that throughput with Firewire).
    I’ll concede my original answer is more vague and makes it sound ideal in a broader range of applications which it isn’t but it shouldn’t be the reason a single RED file is playing back inconsistently.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Eric Sanders
    March 8, 2013 at 2:33 am
    Fair enough – I have observed cases on MacOS 10.6/.7 of RED playback (really, any thing on the disk, but RED is big data enough for it to me more directly observable) being affected by the FW800 controller bridge on some external drive housings, whereas the same file played back on a non-external disk were dandy – hopefully with that in mind a path to joy can be found.
    Cheers,
    -EricS
  • John-michael Seng-wheeler
    March 8, 2013 at 4:00 pm
    Judging by the fact that turning on the Red Rocket makes no image play at all,, I’d say that it isn’t working.
    Try reinstalling the drivers, moving it to a different PCIe slot, etc.
    Does the red footage play smoothly in Redcine-X?
  • Rick Van den berg
    March 8, 2013 at 8:01 pm
    thanks for all the replies.
    the clips are playing nice and smooth in redcineX. also final cut pro x seems to handle them better, but not perfect. btw, a colleague is using a (theoretically slower) mac without a red rocket, and he doesnt have any problems! what the hell..
    i tried to reinstall all the drivers and plugins (again), but still no change. Really don’t know what to do anymore
  • Tom Daigon
    March 8, 2013 at 9:06 pm
    Before I switched to the Z820 I had a 2008 Mac Pro / Quadro 4000 / 24GB ram and a Max Digital raid array. I could play back Red 4K clips just fine at 1/2 resolution (2K).
    Of course the Z820 system has no probs either.
    Wish I could be of more help.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
Page 2 of 2
