Activity Forums Avid Media Composer Nanoflash 720p import trouble
  • Nanoflash 720p import trouble
    Posted by Iain Gray on March 23, 2011 at 1:35 pm
    Hi all,
    I know this has been discussed before but I’ve searched everywhere and can’t get a straight answer.
    I’m using nanoflash with over-cranking to make 720p50 from ex3 into 720p25 slowmo. Avid won’t import these mxf files. It says ‘unrecognized resolution’ but AMA link does work, up to a point.
    Sometimes it gives an error a refuses to link to a file, sometimes it cuts it short, sometimes it displays a different file.
    Does anyone know how to get avid to import these files so they work properly?
    Iain Gray replied 15 years, 3 months ago 2 Members · 2 Replies
  • Mike Daly
    June 2, 2011 at 11:15 am
    Having the same problem here using AVID 5 and the format setup is correct. any help would be appreciated.
  • Iain Gray
    June 2, 2011 at 9:03 pm
    I never got it to work. Officially Avid don’t support these files, Sometimes the Nanoflash obviously creates them in a way that Avid doesn’t like.
    I got round it in the end by bringing the files into another program and converting to another codec. Autodesk smoke is ideal as it can uprez to 1080p and retain a stunning amount of quality. But if you can’t access a smoke there are other packages that’ll do this too.
    Cheers
