Activity Forums Apple Final Cut Pro Naming compound clips?
  • Naming compound clips?
    Posted by David Burch on July 3, 2011 at 11:09 pm
    I was wondering if anybody has found a way to name a compound clip in the timeline to help identify it.
    I have been using compound clips to keep audio tracks in synch and grouped by type, and it would be nice to be able to label the types. For instance, I am currently working on a project with a stereo mix from a house sound board, 2 stage mics, and 2 ambient mics, all recorded in synch on an HD24 hard drive recorder. In the old days I would simply use a tone channel that got sent to my primary video recorder as well to synch up the in points on all my tracks and drop them into the timeline, then rename the source files from FCP. Now, I’m connecting all my tracks at the same playhead marker, making a compound clip of all of them, going into the compound clip and making another layer of compound clips for my stereo board mix, ambience and stage mics. It works pretty well, but gets a little hard to remember which compound clip is what.
    Anyway, if anybody has any ideas, I’m all ears 🙂
    *edit* Ok, I think I may have a solution if anybody’s interested. I can name them if I make empty ones in the event browser first. This seems a little more time-consuming than simply making them in the timeline. I’m still looking for a way to name the clips after creating them from the timeline…maybe this is a feature that will be added later? For that matter, the ability to have compound clips made in the timeline show up in the event browser would be nice too.
    Isabelle Maccrimmon replied 14 years, 9 months ago 6 Members · 8 Replies
  • 8 Replies
  • Tom Wolsky
    July 3, 2011 at 11:32 pm
    Odd that isn’t it that you can’t name them. Good feature request. You can name them if you make the compound clip in the Event Browser. Would be nice if you could rename them, maybe in the Timeline Index.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Brendan Gibbons
    July 3, 2011 at 11:40 pm
    You can name your compound clips that you have created in the timeline….like many things in X, it’s not that obvious.
    Select your new compound clip in the timeline
    Go to the video inspector ( command + 4)
    Choose the “info” tab at the top of the inspector
    By default it is set to “settings view”
    Go to the bottom of the inspector where you see a dropdown menu saying “settings view”
    change this to either basic or extended view.
    Once you have done this you’ll find an editable name field….
    Not exactly obvious is it.
    Cheers,
    Brendan
  • Tom Wolsky
    July 4, 2011 at 1:00 am
    Thanks. That’s obscure, and way more buried than it should be.
    All the best,
    Tom
  • David Burch
    July 4, 2011 at 2:40 am
    Thanks, Brendan. I was just coming here to post the same thing but you beat me to it 🙂 I have to give props to Steve Martin of Ripple Training…he replied to my email within an hour and gave me this solution. Of course, props to Brendan as well for answering my question on here!
  • Matt Callac
    July 4, 2011 at 6:22 am
    [Tom Wolsky] “That’s obscure, and way more buried than it should be.”
    I guess It makes us weird that we want to name something right when we create it.
    -mattyc
  • David Burch
    July 4, 2011 at 9:03 am
    After playing with it for a few hours it’s not so bad if you keep the inspector open all the time, or at least while doing this stage of the edit. It’s funny, the way FCPX works I find myself spending a lot more time on setup than actual editing, but that’s mainly because the edits themselves are much more fluid to do once the setup is complete.
  • David Battistella
    July 4, 2011 at 11:43 pm
    I really like this. Especially when breaking down doc footage. You can cut a clip to bits for audio, make it a compound clip, name it, thematically or by the first few words or the essence.
    Then as you move compound clips around you can structure them just by having a look at the content.
    I used to do this with multiple nested sequences, it’s so much easier now. When you are assembling you can literally look at the words in the timeline and decide, “ok, say this, then this then that, no wait, switch that, etc.” so fast for creating a story.
    David.
    ______________________________
    Believe me. Everything is a lie.
  • Isabelle Maccrimmon
    December 7, 2011 at 4:09 am
    David,
    would you please expand a bit on
    [David Battistella] “You can cut a clip to bits for audio, make it a compound clip, name it, thematically or by the first few words or the essence. “
    My clips are coming in a long lengths as the camera keeps running through the interview. I usually get 2 angles, which I sync into a compound clip, and then break things down via keywords and favorites. I’m still trying to find which method works best for me. But of course, everything still has the compound clips’ name, even though Ideally (or previously in FCP7) I would have broken the thing down into sub clips and renamed each, for ease of navigation once things are cut in the timeline.
    Just curious as to how you break down those sub clips, and do you have to then sync each broken clip individually?
    Isabelle MacCrimmon, Multimedia Associate
    https://www.legacymultimedia.com
    Two-time Winner 2009 Videographer Awards – Award of Excellence, Award of Distinction.
    Winner 2009 Hermes Creative Awards, Honorable Mention.
    View our work at https://www.youtube.com/legacymm
