Activity Forums Apple Final Cut Pro Legacy Name Keeps Changing
  • Name Keeps Changing
    Posted by Raymond Flores on March 28, 2011 at 1:49 am
    I received an hour long b-roll clip of an Agency’s best nature footage.
    I imported the clip and put it in the timeline. I’m using the razor tool to cut the individual scenes like a sunrise or time lapse river shots. I’m dragging the clip into the bin area. The clip looks fine but when I change the name to “Wyoming sunrise” or “river timelapse” all the subsequent clips I’ve put in before change to the newest name.
    I’m use to an AVID work flow and Final Cut is new to me.
    Noam Osband replied 15 years ago 7 Members · 10 Replies
  • 10 Replies
  • Jerry Hofmann
    March 28, 2011 at 1:54 am
    Make subclips instead. Mark and in and out point in the VIEWER then type cmd+u. You can name these anything you want.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Neil Sadwelkar
    March 28, 2011 at 2:18 am
    Or open the clip in the viewer, place markers where you want to mark points of interest, and name the markers. You can even name markers in the browser.
    After you’re done marking, highlight the markers in the browser, then do a Cmd-C and Cmd-V to another bin… and you’ll have subclips. And the original clips will also be tagged.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Raymond Flores
    Thanks Jerry. anyway to zoom in in the viewer that would give me the same kind of control like in the timeline? Trying to find the first frame on an hour long clip is proving difficult.
  • Mark Raudonis
    March 28, 2011 at 3:05 am
    This is a fundamental difference between Avid and FCP.
    You should get in the habit of NEVER, EVER changing the file name in FCP. This will only lead
    to frustration and grief. Better, you make your changes in a “notes” or “comments” column.
    FCP uses the filename to link to media. It CAN handle this renaming, but you are setting yourself up for a disaster if you a) move to a different computer or b) try to do a classic “off-line to on-line” workflow.
    Do yourself a favor and DO NOT bring this habit with you to FCP. There are plenty of other ways to do it OTHER than changing the file name.
    mark
  • Neil Sadwelkar
    March 28, 2011 at 3:18 am
    No you can’t see a ‘source timeline’ in FCP. But the JKL for play rev-pause-play fwd work as well as jjj or kkk to speed up playback either direction work for searching. Then to home in on the frame you an use the right and left arrows.
    Then M to place a mark. M again to rename the marker. We use this to create hundreds of subclips in feature film projects where one gets a ‘roll telecine’ and one needs to subclip all takes of all shots.
    Neil Sadwelkar
    twitter: fcpguru
    Mumbai India
  • Steven Gladstone
    Definitely seems like making a subclip and renaming is the way to go for your work flow. As for zooming in, not sure if this is what you want, but in the Tools menu, you can select keyboard layout, and select customize. There you can make a key zoom into playhead. Perhaps this will help you.
    Steven Gladstone
    https://www.gladstonefilms.com
  • Bret Williams
    March 28, 2011 at 3:36 am
    Make the viewer really wide, and the canvas very small. That’ll give you more scrub room. Or drop the clip in a blank sequence and highlight it and then make markers ON the clip. Not the timeline.
  • Noam Osband
    September 19, 2011 at 4:56 am
    Neil, I’m wondering if you can answer this question. I have your exact workflow for dealing with long clips, but lately, the subclips created from markers arent carrying over the marker name. instead, they are just being given the generic subclip name (“Clip name Subclip 1”). This didnt use to happen and i’m not sure what preference I could have changed or what I could have done to make it happen now.
    But it’s frustrating. Cause I’ve gotten used to this work flow and need to log/create clips out of a few long files.
    Any thoughts?
  • Neil Sadwelkar
    September 19, 2011 at 7:30 am
    If you just place markers and create subclips from them using my method in an earlier reply, then of course the Markers will not have names. If, instead you name the markers in the browser or viewer and then highlight them and do a Cmd-C Cmd-V, the Marker name is retained.
    Neil Sadwelkar
    twitter: fcpguru
    Mumbai India
  • Noam Osband
    September 19, 2011 at 2:31 pm
    That’s precisely my problem: it is not taking the marker name, even when I do Cmd-C and then Cmd-V. Instead, it is renaming it with the generic name it gives subclips without a name. Any other ideas? This is maddening. It was working fine a month ago!
