Activity Forums Apple Final Cut Pro Legacy Mystery .yuv file
  • Mystery .yuv file
    Posted by Wayne Williams on May 4, 2010 at 7:27 pm
    Hello,
    I have acquired a series of .yuv files that I need to transcode to MPEG 2. I tried going to Compressor directly and also doing a file import from final cut pro. Neither seem to recognize it.
    When I do an “info” on it in the finder it displays as file_name.yuv and the kind as a unix executable. The only information that I have on the files are that they are uncompressed video streams.
    Clearly I will need some intermediate tool to enable me to bring into compressor or even identify what I have. Any guidance is greatly appreciated.
    Wayne
    Portland Oregon
    Gary Adcock replied 16 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • Greg Booth
    May 4, 2010 at 7:34 pm
    Hi Wayne,
    .yuv files are uncompressed 8-bit YUV image files, where each .yuv file is a single frame. There typically is no header of any kind – the height/width are determined by looking at the size of the file on disc.
    I believe Shake understands what .yuv files are.
    Hope that helps!
    Cheers,
    Greg
    Calibrated Software
  • Wayne Williams
    May 4, 2010 at 8:11 pm
    Actually the files are on the order of a Gig each, and we have an instrument, the Tektronix Picture Quality Analyzer 500, that is able to read and analyze these files so I am confident that it is a video stream and that they are HD versus a single frame.
    I need to do an experiment that involves transcoding these files to MPEG 2, also I do not have Shake. Any other thoughts on a tool that allows me to bring into Compressor?
    Wayne
  • Greg Booth
    May 4, 2010 at 8:27 pm
    Sorry can’t help then. The only .YUV files I’ve known about are the .yuv image sequence files. Maybe try to see what software/hardware created the file and then go from that.
    Cheers,
    Greg
    Calibrated Software
  • Matthew Bradshaw
    May 4, 2010 at 8:36 pm
    Left field suggestion … why don’t you, make a copy of the files and try changing the suffix or the copies to .mov or dot anything you can think of and see if anything will open those copies.
    Matt.
  • Wayne Williams
    May 4, 2010 at 8:52 pm
    nothing wrong with trying something from left field.
    unfortunately it did not work. thanks for the suggestions, i’ll keep poking around.
    w.
  • Walter Soyka
    May 4, 2010 at 8:59 pm
    Have you tried this?
    https://bax.comlab.uni-rostock.de/en/projekte/glyuvplay.html
    Walter Soyka
  • Matthew Bradshaw
    May 4, 2010 at 9:01 pm
    Can you make the smallest file available? You can email me via my website … https://www.beermattonline.co.uk and you could send me a file via pando or some such. 3 heads are better than one.
    Matt.
  • Gary Adcock
    May 5, 2010 at 2:18 pm
    [Wayne Williams] “I have acquired a series of .yuv files that I need to transcode to MPEG 2. I tried going to Compressor directly and also doing a file import from final cut pro. Neither seem to recognize it.”
    These sound like video files output direct from a Linux system.
    try something- change the .YUV name to .MOV and see if you get an 8 bit 2vuy (uncompressed) video file.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
