Activity Forums Apple Final Cut Pro Legacy Mystery of the log/capture causing FCP shutdown
  • Mystery of the log/capture causing FCP shutdown
    Posted by Karen Weinberg on October 25, 2007 at 12:52 pm
    Hello, hope someone has encountered this…
    So I have an emac (I know, I know) but I’ve souped it up and it’s been fine with Final Cut 5.0.4… recently I upgraded the OS to Tiger 10.4.10 and did all the upgrades that go with that, and FCP still seemed fine, but then it didn’t see my deck when I tried to capture more footage… so I trashed my preferences and reset them, played with the AV settings and then it could see the deck, but now when I try to open the log/capture window the whole program FCP closes.
    Anyone? Bueler?
    Thanks~
    Andy Nitchman replied 18 years, 10 months ago 3 Members · 3 Replies
  • Walter Biscardi
    October 25, 2007 at 2:49 pm
    For DV the eMac is just fine.
    What are you capturing the media to?
    Have you tried “Repair Disk Permissions” in the Disc Utility?
    Walter Biscardi, Jr.
    Stop Staring Start Grading with Apple Color The new Color Training DVD now available!
    https://store.creativecow.net/p/66/stop_staring_and_start_grading_with_apple_color
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Karen Weinberg
    October 25, 2007 at 4:28 pm
    I have now, and I restarted- still shuts down when I try to open the log/capture window… any other ideas?
  • Andy Nitchman
    October 25, 2007 at 9:30 pm
    i had this problem once when tyring to use an older G4 macbook(or whatever they were called then) to capture footage on the road.
    All I can say is check and then double check your capture and av settings.
    also try capturing straight to the internal hard drive as this has worked for me in the past. I know it isn’t ideal but I believe fcp 5 may have some bugs with capturing to firewire drives on older macs.
