Activity Forums Adobe Premiere Pro Mystery Jitter/flicker in Premier sequence but not the source file – how to fix?
  • Mystery Jitter/flicker in Premier sequence but not the source file – how to fix?
    Posted by Rachel Pearl on April 21, 2016 at 5:35 pm
    HI,
    I have a screen capture in a project that is about to go out to a client. When I play the sequence back the screen capture has a bad jitter/flicker. HOwever, when I match back to the clip in the Source window the jittler is not there.
    If I export from the sequence, the resulting Quicktime also has the jitter, which is of course, un-acceptable.
    How do I fix this?
    Rachel
    Rachel Pearl replied 10 years, 4 months ago 2 Members · 2 Replies
  • Jon Doughtie
    April 22, 2016 at 3:15 pm
    What’s the wrapper/codec/resolution of the clip giving you trouble? Interlaced or progressive?
    What are the timeline settings/resolution you are using?
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Rachel Pearl
    April 22, 2016 at 6:34 pm
    The footageis ProRes 29.97, 1920×1080. The sequence is configured to that as well
    It’s progressive scan.
    Does that help?
