Activity Forums Apple Final Cut Pro Legacy mystery error message during recapturing
  • mystery error message during recapturing
    Posted by Martha Stiegman on March 25, 2011 at 8:50 pm
    Hi everyone
    I’m waist deep in a recapturing project from hell.
    I’ve gotten quite a few error messages that read: “an unknown error occurred while trying to reconnect #### clip to the newly captured media. try recapturing the clip to resolve this problem”
    every forum i’ve researched attributes this problem to multiclips. i’ve never made a multiclip. i don’t quite get what a multiclip is.
    any other suggestions about what is causing this would be greatly appreciated.
    thanks
    i’m using FCP6.0.6
    Jerry Hofmann replied 15 years, 5 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    March 26, 2011 at 3:24 pm
    Post more about your setup, and project. What format is the source video? What are you using as a scratch disk, and (maybe the most important question) when was the last time you wiped your hard drive and performed a fresh install from the OS up?
    Also post the format of the drives you’re using for scratch disks. Are they Mac OS extended?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
