Activity Forums Adobe After Effects Mysterious white shadows under arms of keyed subject
  • Mysterious white shadows under arms of keyed subject
    Posted by Dan Caz on May 24, 2012 at 8:00 pm
    I am having this problem in both Premiere using Ultra Key and AE using keylight. Almost everytime I key out a subject and clean everything up as best I can there is this white matter that appears between the arms and body. The closer the arm is to the body the white joins between the two. I don’t know how to get rid of it. Is this a lighting issue?
    Here is a link to some screen shots
    4200_whitematter.jpg.zip
    Daniel Caza
    Dan Caz replied 14 years, 3 months ago 2 Members · 5 Replies
  • John Cuevas
    May 25, 2012 at 12:11 pm
    You posted the result, how about a still of the problematic green screen shot.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Dan Caz
    May 25, 2012 at 2:52 pm
    Here is a green screen shot. It’s not perfectly lit but with a garbage matte the differing shades aren’t a much of a problem. I am shooting with a sony hdr-sr11, a handycam basically but it shoots hd.
    Image here:
    4203_greenscreen.jpg.zip
    Dan Caz
  • John Cuevas
    May 25, 2012 at 5:05 pm
    Dave’s probably correct about the cause of the white. For giggles I tried to key your shot. I turned off “unpremultply result”(big improvement) checkbox, changed the screen gain to 89, screen balance to 51. In the Screen Matte settings I went with clip black to 41 and clip white to 80. Finally I chocked the shot using the Screen Shrink/Grow to -1.0
    Here’s the result(some white left, but not as bad):
    Thinkck.com
  • Dan Caz
    May 25, 2012 at 5:14 pm
    Thanks Dave
    You’re absolutely right – the edges are the worst! The key looks much too smooth and fake by the time I’ve choked the life out of the edges just to clean them up.
    I am really starting to understand the disadvantages of handycam “HD”. It looks fine to just play back but takes a major quality hit when editing. Now that I think of it, bad edges are my biggest problem every time I do green screen, now I know why. Gotta save up I guess.
    Thanks again!
    Dan Caz
  • Dan Caz
    May 25, 2012 at 5:17 pm
    Thanks for the help John
    I wouldn’t have thought to uncheck that box because every tutorial I’ve ever seen on the subject either ignores it or says to keep it checked.
    I’ll give those settings a try. Appreciate it!
    Dan Caz
