Activity Forums Apple Final Cut Pro Legacy Mysterious FCP6 issues.. please helpl!
  • Mysterious FCP6 issues.. please helpl!
    Posted by Julie Hill on October 20, 2007 at 12:42 am
    First the basics:
    8core, radeon x1900, 8gbs of RAM, running FCP studio2 w/magic bullet v.2.
    I am literally pulling my hair out… any help is much appreciated!!!
    1. my project (editing in prores 422) all of a sudden is playing in the canvas as if it is unrendered (it stutters, etc.) even though it was fully rendered… w/blue line above it. played fine the other day! I double checked that I had full quality playback set, and sure enough I did. So then I tried to output it as a self contained QT movie just in case, but it just stalled and then said “general error”. So obviously something is majorly messed up! So then, I went to step 2 which was to trash all the render files and just render the whole thing again. Then…
    2. I got this error: (which I actually get ALL THE TIME… on my other editing systems too… and w/older versions of FCP:)
    “AE Effects Error:
    Rendering error using
    “Misfire Vignette.bundle”.
    Verifty filter parameters.”
    (i use this filter a lot – but never in AE, only in FCP).
    This error seems to pick and choose when it occurs. And it happens on ALL of our 6 editing systems and has happened w/all previous versions of FCP as well which is why, when I decided to look everywhere for an answer, I was shocked to find no information anywhere about this. Usually our “fix-it” is to turn the computer off for a bit, turn it back on and that seems to work, except not today.
    3. After I clicked out of this error message, I noticed that some clips were “halfway” rendered. in other words, part of random clips had the blue line while the other part of a clip had a yellow. I tested the blue part and sure enough.. it still played back as if it was unrendered. (and yes, I have all the render options checked) What gives???
    so then I tried trashing my prefs but I think they are somewhere different in FCP6.
    Thanks in advance to anyone that can help!! 🙂 🙂
    Rafael Amador replied 18 years, 10 months ago 6 Members · 15 Replies
  • 15 Replies
  • Walter Biscardi
    October 20, 2007 at 1:34 am
    [scalvidgal] “1. my project (editing in prores 422) all of a sudden is playing in the canvas as if it is unrendered (it stutters, etc.) even though it was fully rendered..”
    What storage array are you using?
    [scalvidgal] “2. I got this error: (which I actually get ALL THE TIME… on my other editing systems too… and w/older versions of FCP:)
    “AE Effects Error:
    Verifty filter parameters.””
    Is your copy of the effect a Universal Filter for use in FCP 6?
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Julie Hill
    October 20, 2007 at 1:48 am
    Hi Walter,
    I’m using my internal hard drives for storage (I have installed 3 TB’s)
  • Walter Biscardi
    October 20, 2007 at 1:50 am
    Are they RAIDed? What is the speed of the array?
  • Julie Hill
    October 20, 2007 at 2:24 am
    no they aren’t RAIDed, but all 3 of them are working fine. You think it’s a storage issue??
  • Rafael Amador
    October 20, 2007 at 4:02 am
    [scalvidgal] “”AE Effects Error:
    (i use this filter a lot – but never in AE, only in FCP)”
    This have nothing to do with AE. Is only that MagicBullet is a AE like effect. You can not run MagicBullet Editors in AE. AE used the MagicBullet Suit (although the new MB looks will run in all the compatible applications).
    I would suggest you just to download a fresh version of MB Editors and re-install.
    If you think you can be having problems with ProRes, You should duplicate your sequence and change it to Apple 10b Unc, and render a bit to see if is the codec what is causing you problems.
    Right now I have a problem with ProRes (is PAL ProRes Upper or Lower first?).
    A edit a sequence few days ago in 10b Unc (some images from a chopper where I applied the SmoothCam. In 10b Unc plays great in my external CRT connected with my BlackMagic).
    Yesterday I wanted to make a ProRes version to archive it. I just changed the codec in the Setting tab but once rendered I had to trash it because had been rendered with the wrong field order. I’d check it in Shake.
    Rafael
  • Julie Hill
    October 20, 2007 at 4:29 am
    not using magic bullet in AE… only in FCP. That’s why this error is so weird!!!
    Anyway, thx for the tips. I’ll try duping it into another sequence.
    so frustrating!
  • Jonathan White
    October 20, 2007 at 9:26 am
    This is probably of no use but might be related, I recently upgraded to the latest Magic Bullet and an old project which used the misfire vignette gave a big red render error similar to the one you’re getting. I had to remove the old vignette and replace it with one in the new Magic Bullet. No playback issues though, possibly co-incidence…
    Johnny
  • Rafael Amador
    October 20, 2007 at 10:27 am
    You right. When they released the v2, the you could not make work the old projects. All the screen got tinted in red.
    Rafael
  • Uwe
    October 20, 2007 at 2:45 pm
    I dont know if this sounds stupid and ridiculous to you, but I had a problem with FCP not playing back correctly myself on a G5 the other day, and just found out that the video in the canvas-window needed to be fully visible in order to play on the external Broadcast-Monitor (Decklink). So I pressed “fit window” and all was ok again.
    thought I had to share this
    regards Uwe Wiesemann
  • Julie Hill
    October 20, 2007 at 2:57 pm
    Thanks for the suggestions guys!
    Yep, been using v.2 since it’s been out so the compatability issue shouldn’t be an issue (believe me, went through a whole different ordeal w/that) and I’m not using an external monitor so that shouldn’t be an issue either. WEIRD!!!
