Activity › Forums › Apple Final Cut Pro Legacy › Mysterious FCP6 issues.. please helpl!
Rafael Amador replied 18 years, 10 months ago 6 Members · 15 Replies
Anders Haavie
October 21, 2007 at 6:16 pm2. I got this error: (which I actually get ALL THE TIME… on my other editing systems too… and w/older versions of FCP:)
“AE Effects Error:
Rendering error using
“Misfire Vignette.bundle”.
Verifty filter parameters.”This is NORMAL. Normal as in magic bullet is quite buggy, and this problem is very common on all macs It does not have to do with after effects at all. It’s just a generic error message, and don’t worry what it actually says..
I have used used magic bullet ALOT, and I have seen this error message all over the place. Redgiantsoftware claim that this is solved with version 2.2.1. If you look up their webpage supportarea they address exactly this issue. They claim that it will be fixed if you follow their solution. However, it does NOT work for me.
SOLUTION: Buy Magic Bullet Looks. The new version of magicbullet. It NEVER crash and it’s a fantastic upgrade. Red Giant should have fixed version 2, but I don’t have time to care too much about it… move on and buy the upgrade….
Anders
Julie Hill
October 21, 2007 at 6:31 pmAnders…
thanks you!! purchased it and will install immediately 🙂 🙂
Red Giant’s customer service is not the best, but I rely on their filters so much and due for an upgrade anyway! thx!!
Julie Hill
October 22, 2007 at 6:18 pmthis helps!!
Julie,
A) The cause for this error is either one of all of the following:
1. Upgraded from Magic Bullet Editors v1 and still have v1 files on your system.
2. Magic Bullet Editors 2.0 was at one point installed on your current setup.
3. Magic Bullet Editors 2.1 was at one point installed on your current setup
B) To fix this issue, you must uninstall all your Magic Bullet Editors files and re-install with Magic Bullet Editors v2.1.1. Magic Bullet Editors v2.1.1 is required for your current setup (Final Cut Pro 5.1-6.0).
C) View Magic Bullet Editors v2.1.1 installation instructions here:
https://www.rgsupportzone.com/magic_bullet_editors_intel_infoD) For more information, please see the following FAQ:
+ I am receiving this error message: “AE Effects Error: Rendering Error Using Misfire ‘….’.Bundle. Verify Filter Parameters.”
https://www.rgsupportzone.com/magic_bullet_editors#q299
