Activity Forums VEGAS Pro My videos seem blurry and I don’t know how to fix them.
  • My videos seem blurry and I don’t know how to fix them.
    Posted by Sebastian Hernandez on July 7, 2015 at 1:36 am
    Hi, I have searched all over the internet to find out how to fix this problem, but I could not find anything. I have had this forever and I have no idea how to get rid of it. If you notice in the video linked below, around 0:20 – 0:23 the background blurs and and seems to lose quality. (I noticed it a lot in the vines around that time). I don’t know what is making this happen. When I record the video and watch it (without rendering), it seems completely fine and clear. I record with Fraps in 720p and render in 720p. I would like my video to be like the quality in the second video. Thank you for anyone that can help me!
    My video: https://www.youtube.com/watch?v=3RKkfbqPK0Q
    Quality I would like it to be video:
    https://www.youtube.com/watch?v=6grobJ-7DyU
    Steve Rhoden replied 11 years, 1 month ago 6 Members · 15 Replies
  • 15 Replies
  • Steve Rhoden
    July 7, 2015 at 2:16 am
    If you search this forum, you will find this a common issue with
    game capture source, and i have commented on this issue so many times!
    AGAIN, game capture footage are not edit friendly, you will have
    these issues or other issues no matter what you do or what you use…
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Bob Peterson
    July 7, 2015 at 3:02 am
    I think you are seeing something that virtually no one else will ever see. Things are moving past so rapidly that it is hard to see any detail at all.If you are talking about the sky when you say “background”, I saw no noticeable differences between the two videos.
    I’m not sure who your intended audience is, but I am quite sure that the average person will not see what you are obsessing over. Anyone who can see a difference between these two, fast moving videos has way too much time on their hands. I’m just sayin….
  • John Rofrano
    July 7, 2015 at 11:04 am
    [Sebastian Hernandez] “If you notice in the video linked below, around 0:20 – 0:23 the background blurs and and seems to lose quality. (I noticed it a lot in the vines around that time). I don’t know what is making this happen.”
    It’s happening because of the way that particular video codec (AVC/H.264) handles compression. It’s recoding a Group of Pictures that is 15 frames long (called Long GOP). Only one in every 15 frames is a whole frame and the rest are delta and predictive frames that only contain the differences from the last full frame. Just before 0:20 the entire picture changes to show that big grey square with the black background. When the square disappears, the scene changes so much that the delta frames can’t possible display the difference with great accuracy so the scene looks blurry until the next full frame can refresh all of the pixels. It’s inherent in the way MPEG4 encoding works. FRAPS does’t use Long GOP so it doesn’t have this problem. YouTube does.
    I agree with Bob. I can’t see the difference between the videos. They both get blurry at points and then look clearer again. It’s just the way that video encoding works. The only way to get rid of it is to not use a Long GOP codec which you don’t have any control over, because YouTube does.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Sebastian Hernandez
    July 7, 2015 at 4:59 pm
    I’m sorry that was the same video in each. Here is a video example of how I would like the video to be: https://www.youtube.com/watch?v=6grobJ-7DyU
  • John Rofrano
    July 7, 2015 at 5:05 pm
    [Sebastian Hernandez] “Here is a video example of how I would like the video to be: “
    This map has a lot more solid gray colors that yours which was mostly the green with a lot of variations. That could be one reason his is cleaner although he may be using a better encoder like Handbreak.
    Why don’t you just ask him how he processes his video?
    ~jr
    July 7, 2015 at 6:15 pm
    Here is another video that is played on the same map. And how would I use a better encoder like handbreak? Thank you.
    https://www.youtube.com/watch?v=M1DRSpJovUE
  • John Rofrano
    July 7, 2015 at 7:02 pm
    [Sebastian Hernandez] “And how would I use a better encoder like handbreak?”
    You output to a lossless format like Lagarith from Vegas Pro and import that into Handbreak and have it create your mp4 file for you. I don’t bother doing this so I can’t give you any particulars about what parameters to tweak but you should really ask that person what they use because not all encoders are the same.
    ~jr
    July 7, 2015 at 7:39 pm
    I tried this and I still get the same quality. I don’t know him personally so i wouldn’t be able to ask cause he probably won’t respond. I have no idea how to remove it because most people I watch don’t have this problem
  • Rick Hughes
    July 7, 2015 at 7:51 pm
    Is your intent to share on-line ….. is so then no matter what you do Youtube will alter quality as it transcodes uploads.
    Worth looking at Vimeo .. and in particular the section on encoding:
    https://vimeo.com/help/compression
    Vimeo provides HD quality if user chooses to playback in HD ………. with Youtube there are several playaback options but none as good as Vimeo.
    July 7, 2015 at 7:52 pm
    No but I want it on youtube. Not only that but there are tons of people on youtube that do the same types of videos and never have this problem.
