Activity Forums VEGAS Pro My sony vegas 11 saves the MP4 video as name.mp4.tmp
  • My sony vegas 11 saves the MP4 video as name.mp4.tmp
    Posted by Justin Coolidge on August 23, 2014 at 11:36 pm
    so when ever i render my video it saves a name.mp4.tmp file. but then i rename the file to name.mp4 and it turns into the video file. but then there is another problem, if i import that renamed video into vegas it gets stuck (not responding) and then crashes. what should i do?
    and also after rendering, the “open” option is grayed out during this problem & the finished video has audio out of sync. if the problem doesn’t happen (only 20% chance) audio & video is not out of sync
    Dave Osbun replied 12 years ago 4 Members · 4 Replies
  • John Rofrano
    August 24, 2014 at 12:23 am
    [Justin Coolidge] “so when ever i render my video it saves a name.mp4.tmp file.”
    It sounds like for whatever reason your renders are not completing. You should not be seeing tmp files. You should just have the name.mp4 at the completion of the render. I don’t know what’s causing this but something isn’t right.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Rofrano
    August 24, 2014 at 1:46 am
    Your post made it sound like you thought this was normal behavior because you were renaming the files and trying to use them in Vegas. I was just pointing out that it wasn’t. If that was obvious to you then ignore my post. We have people of all skill levels posting so I don’t know how much you already know.
    ~jr
  • Bill Burnette
    August 24, 2014 at 2:56 am
    The .tmp file is an intermediate. The render is not complete. I believe it has finished the timeline but needs to do some post-process. For longer mp4s, it can take a while sitting at 100%, with [open] greyed out and the .tmp file sitting there. Wait a while longer. It’s likely that your renaming the file would mess something up.
  • Dave Osbun
    August 24, 2014 at 4:45 pm
    You have some nerve posting this garbage after somebody tried to help you. Just so you know, John Rofrano is probably THE most knowledgeable member of this message board.
    Go take your bad attitude elsewhere. We are all nice and well-mannered here. You don’t fit in.
