My rendered Hd video lacks when i play it in Vlc/media player.
Posted by Allan Boes on July 22, 2011 at 8:51 pmWhen i try to playback my Hd video in vlc player/windows Medie player it totally lacks?
Is that a codec problem?
If so what codec am I to use and, how do you add them to Vegas pro 10?Allan Boes!!!
Working in Vegas pro 10John Rofrano replied 15 years, 1 month ago 2 Members · 6 Replies -
John Rofrano
July 23, 2011 at 1:38 pm[Allan Boes] “When i try to playback my Hd video in vlc player/windows Medie player it totally lacks?”
What do you mean by “lacks“? Can you post a screen shot?
[Allan Boes] “Is that a codec problem?”
It could be, or it could be a bit-rate problem. What codec and bit-rate did you use?
[Allan Boes] “If so what codec am I to use and, how do you add them to Vegas pro 10?”
You shouldn’t be adding any codecs. Did you install any codec-packs? This could be why your video is bad.
I would use the Sony AVC codec with the Internet 1280×720-30p (or 25p for PAL) if you are planning to watch on your PC or the Internet.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
John Rofrano
July 23, 2011 at 10:18 pmUnfortunately none of those screenshots show the video properties. BTW, your audio properties are wrong. Audio for video should be 48K not 44.1K. If I were you, I would stop making my own templates and just use the built in templates that come with Vegas Pro.
Also, I still don’t know what you mean by “lacking”.
~jr
Allan Boes
July 24, 2011 at 1:45 am -
John Rofrano
July 24, 2011 at 1:09 pm[Allan Boes] “By lacking I mean that the vlc player stops the picture/sound all the time, and for that reason it cant play my videos made in Vegas smooth. “
That’s because you are rendering uncompressed HD and unless you have a RAID 0 array with at least 5 drives you are not going to play this back smoothly. There is no reason to be rendering uncompressed video and it is certainly not a final delivery format that anyone can play smoothly.
[Allan Boes] “What are the best setting for rendering in HD,if i dont want to loose any Quality at all?”
I belive I already told you that. I would use the Sony AVC codec with the Internet 1280×720-25p template if you are planning to watch on your PC or the Internet. You shouldn’t see any noticeable loss in quality. If you do, just increase the bit-rate in the template.
~jr
