Activity › Forums › VEGAS Pro › My project keep crashing when i open it
  • My project keep crashing when i open it
    Posted by Ali Johnson on July 25, 2009 at 9:34 am
    I want to open it and edit it further, then save it,but for some reason it stops at 23% and don’t finish loading up, so I can finish my video.
    Please help me
    Miriam Franceschini replied 13 years, 2 months ago 5 Members · 5 Replies
  • Steve Rhoden
    July 25, 2009 at 1:15 pm
    Try different methods of opening the file…..
    Import/open from within vegas.
    And with vegas close, right click on the file and
    choose open with and choose Vegas.
    Just make sure none of the original files that was used
    in the project was not moved to another folder etc or deleted.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
  • Ali Johnson
    July 27, 2009 at 1:09 am
    Well, I went to import then click media,then I went to files of type clicked on All files (*.*),and then I clicked on Myproject.veg.bak
  • Mike Kujbida
    July 27, 2009 at 2:34 am
    Any veg file with a .bak extension is your backup project file, not the main one.
    Look for Myproject.veg first and try loading that one.
    It should be in the same folder as Myproject.veg.bak.
    If not, do a search of your computer for it.
    If you still can’t find it, rename Myproject.veg.bak to Myproject.veg and try opening that one.
  • Omer Aydin
    July 27, 2009 at 1:29 pm
    If you still can’t open the project using the way Steve Rhoden suggested, try moving all media files used in the project to a sub folder so Vegas can’t find them.
    When it asks for the missing media files during loading, show the new location one by one. If the hang is due to a media file, then it will hang once you import it. Once you detect the file causing the problem, skip loading that media and you’ll be able to open the project.
    If it doesn’t load even you skip all media, then it might be a damaged/corrupted .VEG file. Try opening the .veg.bak file.
  • Miriam Franceschini
    July 1, 2013 at 9:22 pm
    Omer Aydin……I LOVE YOU!!!!
    Thanks thanks..THANKS SO MUCH!!!
