Activity Forums Apple Final Cut Pro Legacy my project is too big
  • my project is too big
    Posted by Michael Butler on July 27, 2011 at 9:31 am
    Hi, i have a slight problem. i have put together a fifteen minute clip for a friend and wanted to post it on youtube. The Clip is 2.07 GB and youtube only lets one upload clips that are 2GB. The clip was shot in SD and i have edited the clip in SD and exported it using quick time converter. the format that it is in is apple prores 422. I am working off an iMac. what would be the best program to use with regards to converting the final product into a smaller format, or should i just go back to the original project in FCP and try and make a few of the clips shorter. i would like to try and avoid the second option because it is synced with music.
    Michael Butler replied 15 years, 1 month ago 3 Members · 6 Replies
  • Everest Mokaeff
    July 27, 2011 at 11:45 am
    Use Share/Compressor preset for youtube. Leave default settings they’ll do just fine. Available since FCP7.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Michael Butler
    July 27, 2011 at 1:54 pm
    Is Share Compressor on the youtube website, or is it a program that i would have to download?
  • Michael Butler
    July 27, 2011 at 1:57 pm
    Is the Share/Compressor relatively easy to find on youtube, or is it something that has to be downloaded?
  • Everest Mokaeff
    July 27, 2011 at 2:39 pm
    Share is a feature since fcp 7 that, among other things, transcodes for and upload to youtube. Compressor is a separate application from Final Cut Suite 3.
  • James Daugherty
    July 28, 2011 at 9:33 pm
    https://www.kenstone.net/fcp_homepage/fcp_7_share_stone.html
    Try this link. I think it will explain everything you need to know to share from FCP7.
    James Daugherty
    President SDFCPUG.com
  • Michael Butler
    August 2, 2011 at 9:32 am
    thanks very much.
