Activity Forums VEGAS Pro My photos are animating with many horizontal lines throughout.
  • My photos are animating with many horizontal lines throughout.
    Posted by David Lincoln brooks on May 10, 2010 at 4:58 am
    I’ve got an sequence with 6 still photos rotating in a circle.
    My photos are animating with many horizontal lines throughout. It’s pretty bad.
    Can it be fixed?
    Thanks, DAVE
    John Rofrano replied 16 years, 4 months ago 3 Members · 2 Replies
  • Theo Van laar
    May 10, 2010 at 7:12 am
    Did you activate the ‘reduce interlace flicker’ option?
    Theo
  • John Rofrano
    May 10, 2010 at 9:53 am
    …and if that isn’t enough to fix it, try adding a slight Gaussian Blur around 0.001 – 0.002 in the vertical direction only.
    This is happening because the video is interlaced into fields that are only shown 1/2 the time. If a line is thinner than 2 fields high it will flicker each time the field is turned off.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
