Activity Forums Adobe After Effects my object moves – BUG?
  • my object moves – BUG?
    Posted by Manny Rellesiva on September 22, 2005 at 9:40 pm
    I occassionally encounters this: the layer moves even the following keyframe i created does not change its position.Why does it happen?
    Avrohom Kohn replied 21 years ago 3 Members · 3 Replies
  • Avrohom Kohn
    September 22, 2005 at 11:32 pm
    First of all, you might have animated the anchor point. If you didn’t, make sure your position path is not curved between these two keyframes. This might have happened if your path is curved on the previous keyframe, so when you set a keyframe a little further down the timeline, it’s automaticly going to curve it in the opposite direction. To fix that you might want to try the following: Cmd-click (control-click on windows) on the handle that’s on the opposite end of the curve (to seperate it from the other handle) and drag it towards the keyframe (till it’s on the keyframe) that way it takes away the unwanted curve, than use the other handle to fine-tune your previous curve.
    I hope this is the solution,
    -A.N.
  • Jim Zito
    September 23, 2005 at 1:34 am
    Try right-clicking on the keyframes and choose KEYFRAME INTERPOLATION and change SPACIAL INTERPOLATION to LINEAR.
    Jim
  • Avrohom Kohn
    September 23, 2005 at 2:33 am
    I understood the question that the animation should stay the same till the two keyframes with the same position. By changing the spatial interpolation to linear, he will lose the curve before the still keyframes.
    Another way to achieve that is to control-click (right-click on windows) on the first [still] keyframe, and click on the “toggle hold keyframe” which will keep the image from moving till the next keyframe.
    -A.N.
