Activity Forums Apple Final Cut Pro Legacy MY Network thinks I’m running the same copy of FCP.
  • MY Network thinks I’m running the same copy of FCP.
    Posted by Deno Sig on February 28, 2012 at 5:18 pm
    I recently had a problem updating a G5 machine running Tiger and FCP Studio 1 to Leopard and FCP Studio 2.
    Once I had FCP 6 loaded and the OS I couldn’t get the updates to 6.0.6 for some reason.
    So I started over by wiping out everything and reinstalling tiger then FCP Studio 2 which found the updates this time and then updated to Leopard.
    Now that I have all my updates in place FCP 6.0.6 won’t open unless I’m disconnected from the Network. I’m Getting the message that I’m running the same serial number on another computer connected to the network which isn’t true. It was originally the same machine just erased and reinstalled.
    Does anyone have any ideas on what may be the problem?
    Thx
    D
    Deno Sig replied 14 years, 6 months ago 2 Members · 2 Replies
  • Steven Cohen
    February 28, 2012 at 5:43 pm
    Try deleting and re-entering your serial #.
    You may have accidentally entered the same # on 2 machines.
    You can deleted the file that stores the Serial # at /Library/Application Support/ProApps
    Then delete the one that says Final Cut Studio System ID or Final Cut Pro System ID.
    The next time you launch Final Cut it will ask for the serial # again as if it is a new install.
  • Deno Sig
    February 28, 2012 at 6:04 pm
    Thanks I gave it a try and it’s still the same after I put in the SN#
