Activity Forums Apple Final Cut Pro Legacy My Markers Keep Moving on Speed Change
  • My Markers Keep Moving on Speed Change
    Posted by Ally Shore on July 31, 2009 at 10:40 pm
    Has anyone had this problem? I set a number of markers on a clip. Later during the edit, I needed to change the speed on that source clip. When I set it back to the original speed, all of the markers had moved and many had vanished. Is that normal? Do I need to duplicate a clip every time I want to make a speed change without using the markers? Any ideas how to get the markers back?
    Ally
    Nick Meyers replied 17 years, 1 month ago 3 Members · 4 Replies
  • Steve Eisen
    August 1, 2009 at 1:09 am
    Must be using FCP 6 or earlier. This is normal. Markers now stay in sync with your clips in FCP 7.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Ally Shore
    August 1, 2009 at 4:00 am
    Steve,
    thanks for the feedback. Do you know if it’s retro-active? If a clip is already screwed up from 6.06, will it go back into sync in 7.0?
    Is there anyplace you know of to get more info on changes like this to 7 that don’t seem to show up on the “What’s New in 7” lists?
    thanks
    Ally
  • Steve Eisen
    August 1, 2009 at 4:49 am
    I don’t know if it’s retro active. I have not tried it.
    Check out this pdf. search markers.
    https://images.apple.com/finalcutstudio/docs/Final_Cut_Studio-In_depth.pdf
    Steve Eisen
    Board of Directors
  • Nick Meyers
    August 1, 2009 at 2:44 pm
    yes, i have seen this in FCP < (less than) 7 good to know this has been addressed. (I can't update here in Aus as the shipment hasn't arrived!) no way in the world will this be retro-active... sorry. you could look thru your auto save vault to find the clip before you changed it's speed nick
