Activity Forums Panasonic Cameras My first HD job to SD
  • My first HD job to SD
    Posted by Lars Wikstrom on October 26, 2006 at 9:05 pm
    Well I ran the tests and decided on shooting it at 720p 60p. When I created an SD timeline and drag dropped the HD timeline into the SD time line and scalled it down it looked ok. I then exported the footage to After Effects and did the conversion in there and the results were night and day. I did a speed change to slow the footage down since it was 60p. Then when I rendered out the footage an selected lower feild first for interlacing (Since the source was 60p) it created a much better image then draging a HD timeline into an SD timeline in FCP.
    Thanks for the help!
    -Lars
    Lars Wikstrom replied 19 years, 10 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    October 26, 2006 at 9:48 pm
    One more test. Export your movie to compressor and do an advanced format conversion to whatever format/codec you need. You can play with the frame controls for better results, but longer render times.
    Jeremy
  • Lars Wikstrom
    October 26, 2006 at 10:58 pm
    I’ll give that a try, thanks.
    -Lars
